Table 16. Stand-Alone Synchronizer Command-Line Options
Default Value and Usage Notes |
Help |
Optional |
Provides online help for usage. |
/a |
Autostart mode |
Optional |
Available modes are Y or N. |
/ApplyTxns |
Apply transactions during this synchronization |
Optional |
Determines whether or not transactions will be applied to the local database during the current synchronization operation. Available modes are Y or N. Defaults to Y. A value of N directs transactions to be downloaded and uploaded, but not applied. |
/c |
Configuration file |
Required |
The default is siebel.cfg. |
/comm |
Communication parameters |
Optional |
Used for modem connections. |
/d |
Data source |
Optional |
The default is local. |
/help |
Help |
Optional |
/i |
Iterations |
Optional |
Sets the number of iterations. |
/l |
Language |
Optional |
Language to use for the docking session. |
/n |
Client name |
Required |
Name of Mobile Web Client. The value must be entered using uppercase letters. |
/p |
User password |
Required |
Database connection password. The value must be entered using uppercase letters. |
/p2 |
Confirmation password |
Required |
Required when initializing. |
/ParallelApply |
Apply transactions in parallel with data transfers |
Optional |
Determines whether transactions will be applied to local database while other transactions are still being transferred between client and server, or whether all transactions will be applied after data transfer is complete. Available modes are Y or N. Defaults to Y. This option is ignored if the ApplyTxns option is set to N. |
/RecvAutoUpdFiles |
Receive auto updates to files |
Optional |
Determines whether Mobile Web Client will download updates to requested files. Available modes are Y or N. |
/RecvFiles |
Receive files |
Optional |
Determines whether Mobile Web Client will download files from server. Available modes are Y or N. |
/RecvPubFiles |
Receive published files |
Optional |
Determines whether Mobile Web Client will download published files. Available modes are Y or N. |
/RecvTxns |
Receive transactions |
Optional |
Determines whether Mobile Web Client will download transactions from server. Available modes are Y or N. |
/SendTxns |
Send transactions |
Optional |
Determines whether Mobile Web Client will send transactions to server. Available modes are Y or N. |
/sleep |
Sleep time |
Optional |
Number of seconds to sleep between iterations. |
/u |
User name |
Required |
Database connection user name. The value must be entered using uppercase letters. |
/v |
Verbose mode |
Optional |
