| Metadata Definition XML Metadata External application metadata | n	Integration objects based on Siebel business objectsn	Integration objects based on external metadata | In any integration project, you need a way to supply data about data, called metadata. Siebel Financial Services applications provides XML as the common format for representing external application data. In addition, Siebel Financial Services applications provides an object type in Siebel Tools called the Integration Object, as well as an Integration Object Wizard, which automates the task of creating integration objects. |
    | Data Transformation Declarative data transformation mapping  High-performance transformation engine |  | Siebel Financial Services eAI allows you define what type of data is to be exchanged, and allows you to export a DTD for a Siebel integration object. |
