| Bookshelf Home | Contents | Index | PDF |    |
| Siebel Financial Services eBusiness Application Integration Guide > Siebel Financial Services eAI Architecture > Industry XML Connector > Industry XML Data Transformation EngineThe Industry XML Data Transformation Engine transforms the hierarchy between external and internal data models that are represented by integration object instances. The Industry XML Data Transformation Engine is designed to handle heterogeneous messages to allow more than one business object scenario. It also takes extra input arguments specified in the data transformation map to indicate the possibility of removing empty value tags from the instances transformed. Table 8 lists the specific methods for the industry XML Data Transformation Engine. Industry XML Data Transformation Engine business service uses combinations of method, and method arguments to achieve different tasks.Table 9 lists all the method arguments available to use with Industry XML Data Transformation Engine business service. Each method defined for the Industry XML Data Transformation Engine business service takes some input arguments and produces some output arguments as listed in Table 10 and Table 11. |
| Siebel Financial Services eBusiness Application Integration Guide |
