| Siebel Financial Services eBusiness Application Integration Guide > Overview > Details of Siebel Financial Services eAI > Extensible
 Siebel Financial Services eAI can be extended using standard class derivation or API implementation. You can extend the generic industry XML connector by modifying its user properties and implementing the Siebel Industry XML Connector Factory APIs to support other industry XML standards. The Industry XML Connector provides the following services that are required in most industry XML standards.
Figure 3. Customized Industry XML Connector Architecture
