| Siebel Financial Services eBusiness Application Integration Guide > Financial Services eAI Business Scenarios > Data Sharing Across the Enterprise > ERP Integration
 In this scenario, the main purpose is the correct and timely fulfillment of an order, but the back-end is now a popular ERP application. Siebel has developed prebuilt solutions that interface with SAP R/3, PeopleSoft, and with Oracle applications (both for the character-based 10.7 release and the GUI and web client release 11i). These applications are set up to exchange order information, customer information, and so on, out-of-the-box. Additionally, they can be customized as needed to exchange as much or as little information from these external applications as your situation requires.  Table 31 details the requirements and the solution for a successful integration of ERP data.
Table 31. ERP Integration Requirements
    |  | Technological Requirement |  |
    | To create an order against SAP R/3 | Integration with popular applications | Siebel eBusiness Application Integration Connector for SAP |
