Security Guide for Siebel Business Applications > Configuring Access Control > Access Control Mechanisms > About Manager Access ControlYou can indirectly associate a position with data associated with subordinate positions in a reporting hierarchy. For example, in the My Team's Opportunities view, an employee with a particular active position can see opportunities associated with that position and opportunities associated with subordinate positions. Manager-subordinate relationships are determined from a position hierarchy. One position hierarchy is included as seed data when you install your Siebel application. You can specify one parent position for a position, which represents that the position is a direct report to the parent. The parent of an internal position may be in the same division or a different division. For example, a sales manager in the Sales division may report to a sales vice president in the Corporate division. In a view using manager access control, this employee or partner user has access to data according to the following behavior:
Views that apply manager access control generally contain the phrase My Team's in the title, such as My Team's Accounts. (In some cases, the word My is omitted.) There are no business component view modes specific to manager access control. Manager access control is set at the view level. It requires that the business component on which the view is based has a view mode with owner type Position or Person. NOTE: In a view using manager access control, if the manager user has no subordinate positions defined, the user cannot create new records in the view. The New button and the New Record command are unavailable. For information about business component view modes, see Business Component View Modes. For information about implementing access control in a view, see View Access Control Properties. |
| Security Guide for Siebel Business Applications |
