Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Reports Server > Installing the Siebel Report Design Products > Installing Actuate e.Report Designer ProfessionalActuate e.Report Designer Professional offers developers of structured content for the Windows platform the added capability of designing, building, and distributing report object designs and components throughout the enterprise. Installation of Actuate e.Report Designer Professional is not required to run the Siebel Reports Server. If you install Actuate e.Report Designer Professional, you must install it on a developer machine that has Siebel Tools installed on it. NOTE: The following procedure is for installing the base product. For patch installation instructions, refer to the Maintenance Release Guide provided with the patch. See also About Installing Siebel Releases. To install Actuate e.Report Designer Professional
Compiling Reports with Actuate 7The Actuate 7 e.Report Designer Professional (erdpro) compiler is more stringent and catches errors that might have been ignored in earlier Actuate versions. To provide backward compatibility for reports developed with Actuate 5.x or 6.x, which fail when compiled with Actuate 7, use the following compilation instructions. To compile reports with Actuate 7
NOTE: This solution may also apply to new reports created with Actuate 7 erdpro that fail compilation due to |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
