Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Installing the Siebel Reports Server > Installing the Siebel Report Design Products > Installing Actuate e.Report DesignerActuate e.Report Designer lets developers for the Windows platform design and create reports, using its graphical user interface. Installation of Actuate e.Report Designer is not required to run the Siebel Reports Server. If you install Actuate e.Report Designer, you must install it on a developer machine that has Siebel Tools installed on it. NOTE: The following procedure is for installing the base product. For patch installation instructions, refer to the Maintenance Release Guide provided with the patch. See also About Installing Siebel Releases. To install Actuate e.Report Designer
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
