Table 7. DB2 UDB Configuration Parameters
DFT_DEGREE
Degree of parallelism (1=turn query parallelism off). |
1
DFT_QUERYOPT
Default query optimization class. This parameter only takes effect on the database server and affects the Siebel Server components, such as Siebel EIM or Siebel Remote. Queries run through the UI are not affected by this setting. They take the value of the Siebel system preference DB2: Default Opt Level, or you can override them at the business component level using Siebel Tools. |
3
DBHEAP
Database heap (4 KB). |
7429 (32-bit)
10000 (64-bit)
CATALOGCACHE_SZ
Catalog cache size (4 KB). |
5558 (32-bit)
8000 (64-bit)
LOGBUFSZ
Log buffer size (4 KB). |
256
UTIL_HEAP_SZ
Utilities heap size (4 KB). |
5000 (32-bit)
10000 (64-bit)
LOCKLIST
Maximum storage for lock list (4 KB). |
25000 (The setting should never be smaller than this, but may be increased.)
APP_CTL_HEAP_SZ
Maximum applications control heap size (4 KB). Controls the number of users that can be included within one connection to the database. |
900
For customers using the Siebel connection pooling feature, for best scalability, increment the parameter by 1200 for each 10 users per connection. |
SORTHEAP
Sort list heap (4 KB). Lower values should be used for development environments; higher values for production. However, increasing this value can lead to insufficient memory on the database server. Also, this parameter may need to be set below the recommended range if you have a high number of Siebel users. Therefore, you need to always monitor database server memory and performance to find the best setting for your environment. |
1000-5000
STMTHEAP
Minimum setting. If needed, this parameter should be incremented in 1048 blocks. |
40960
STAT_HEAP_SZ
Statistics heap size (4 KB). |
14000 (32-bit)
20000 (64-bit)
MAXLOCKS
Percentage of lock lists per application. |
20 (32-bit)
30 (64-bit)
LOCKTIMEOUT
Lock time out (seconds). |
300
CHNGPGS_THRESH
Changed pages threshold. |
30
NUM_IOCLEANERS
Number of asynchronous page cleaners. |
Number of CPUs. |
INDEXSORT
Index sort flag. |
YES
SEQDETECT
Sequential detect flag. |
YES
DFT_PREFETCH_SZ
Default prefetch size (4 KB). |
32
LOGRETAIN
Sequential or circular log files. |
RECOVERY
Set this parameter to RECOVERY in a production environment. Otherwise, you will lose data should your database crash. When LOGRETAIN is set to RECOVERY, you must also activate USEREXIT or implement another method to manage the archived logs, so that LOGPATH does not fill up. |
MAXAPPLS
Maximum number of active applications. |
Twice the number of users. |
AVG_APPLS
Average number of active applications. |
Depends on the environment. |
MAXFILOP
Maximum DB files open per application. |
500
LOGFILSIZ
Log file size (4 KB). |
40000 |
LOGPRIMARY
Number of primary log files. |
25-50
The value of LOGPRIMARY and LOGSECOND together may not exceed 128. |
LOGSECOND
Number of secondary log files. |
Up to 103 The value of LOGPRIMARY and LOGSECOND together may not exceed 128. |
ESTORE_SEG_SZ
Deployments with servers with more than 4 GB of RAM can take advantage of this extended storage parameter. Use of this parameter also improves application sorting. Attach 4-KB and 16-KB buffer pools. NOTE: The setting should be subject to your performance testing.
Initially 0 but can be up to 65536. |
SOFTMAX
Percent log file reclaimed before soft checkpoint. |
80
APPLHEAPSZ
Default application heap (4 KB). |
2500
PCKCACHESZ
Package cache size (4 KB). |
40000 |
NUM_IOSERVERS
Number of disks on which the database resides. |
Number of disks. |
