Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools > Configuring the RDBMS > Configuring IBM DB2 UDB for Siebel Applications > Guidelines for Setting Up DB2 UDB BufferpoolsA bufferpool is an area of main system memory that is used for holding pages of data that have been fetched from the table space. In DB2 UDB, each table space is associated with a bufferpool. Adding more space to a bufferpool enhances the performance of the database. You must have at least three bufferpools for the Siebel table spaces. You can use the default bufferpool (called You must also create additional bufferpools with 16-KB and 32-KB page sizes for sorting and other SQL processing. A sample configuration is shown in Table 8. Different operating systems support different maximum amounts of DB2 addressable memory. Depending on the memory configuration of a given server, the suggested pool sizes for |
| Siebel Installation Guide for Microsoft Windows: Servers, Mobile Web Clients, Tools |
