Upgrade Guide > Siebel Postmerge Development Tasks > Reviewing Objects Deleted from the Siebel RepositoryUpgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Deleted objects are those that were in the repository when it was installed but that you have since deleted. The merge retrieves these objects from the Prior Siebel Repository and adds them to the New Customer Repository. Typically, adding these objects does not cause a problem with your upgraded configuration. Prerequisite: The repository merge must have been successful. See Determining if a Siebel Repository Merge was Successful. To generate a list of deleted objects
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
