Upgrade Guide > Siebel Postmerge Development Tasks > Reviewing Obsolete Objects in the Siebel RepositoryUpgrades: All Siebel upgrades. Environments: Development environment only. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Objects that were available in the Prior Siebel Repository but are not available in the New Siebel Repository are obsolete. After performing the repository merge, you can generate a list of obsolete objects using Siebel Tools. Objects that were available in the Prior Siebel Repository are compared with the objects that are available in the New Siebel Repository. Prerequisite: The repository merge must have been successful. See Determining if a Siebel Repository Merge was Successful. To generate a list of obsolete objects
| Upgrade Guide | Copyright © 2006, Oracle. All rights reserved. | |
