Upgrade Guide > Postupgrade Tasks for the Siebel Database and File System >
Validating Dock Objects and Rule Definitions in the Siebel Database
Upgrades: All Siebel upgrades. Environments: Development, production test, production. This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade. Changes to visibility rules and dock objects require the assistance of Oracle's Siebel Technical Support or Oracle's Siebel Expert Services. If you deploy Siebel Business Applications to mobile users with local databases, you can run the DICTUTL utility to verify that all dock objects and rule definitions are correct. Dock objects allow mobile users to synchronize their local databases with the Siebel Server. Rules determine which data users synchronize. For more information about dock objects and rules, see Siebel Tools Online Help and Siebel Remote and Replication Manager Administration Guide. Related Topic
Preserving Siebel Dock Objects and Visibility Rules To verify that all dock object and rule definitions are correct
- Navigate to the following directory:
Windows: SIEBEL_ROOT\bin
UNIX: $SIEBEL_ROOT/bin
- Type the following command using the parameters specified in
Table 39:
dictutl /C ODBC_DATASOURCE /U USERNAME /P PASSWORD /D TABLEOWNER /N "REPOSITORY_NAME" /A y 2> logfile.log
Table 39. Command Line Flags for DICTUTL
/C |
ODBC_DATASOURCE
ODBC datasource name |
Yes |
/U |
USERNAME
User name to log in to database |
Yes |
/P |
PASSWORD
User password to log in to database |
Yes |
/D |
TABLEOWNER
User name of tableowner |
Yes |
/N |
"REPOSITORY_NAME"
Name of repository for dictionary (the parameter must be bounded within double quotes) |
Yes |
/A |
y or n
Enter the y parameter to ignore the dictionary cache. Enter n if you do not want to ignore the dictionary cache. |
Yes |
- Review the
LOGFILE.log file:
- Open the file in Microsoft Excel. If the file is too large for Excel to display the whole file, break the file into two files and examine each separately.
- Query for the word error.
- If you locate errors, write down the exact error text.
- Query for the word syntax.
- If you locate syntax errors, write down the exact error text.
- Contact Oracle's Siebel Technical Support to determine if the errors must be resolved.
The following types of entries indicate that no errors were found:
