Upgrade Guide for DB2 UDB for z/OS > How the Upgrade Works > Job Flow of a Production Database (Mainframe-Centric) Upgrade >
Key Members in a Mainframe-Centric Upgrade
Members in the DSNHLQ.SIEBEL.EXEC contain useful information that you can refer to when performing your mainframe-centric upgrade. These key members are listed in Table 10.
Table 10. Key Members in the DSNHLQ.SIEBEL.EXEC
@JOBPRFX |
Shows details of the job prefixes chosen for the upgrade. |
@LASTJOB |
Lists the job name of the last job for each step of the upgrade, for example:
- PRESCHM:S003562Z
- PRESCHF: S006463Z
@SRCTAR |
Lists details of the source and target environments, for example:
- SOURCE: HOSTNAME=QA02 DB2SYS=Q2F1 TABLEOWNER=CQ2F1001
- TARGET: HOSTNAME=QA02 DB2SYS=Q2F1 TABLEOWNER=CQ2F1900
@TBOSRC |
Provides source tableowner details. |
@TBOTAR |
Provides target tableowner details. |
@UPGPATH |
Lists the upgrade path and the upgrade status, that is, the last step executed, for example: PATHID=2 STEP=4 - NEW SIEBEL GP INDEX REBUILD JOBS GENERATED |
@UPGTYPE |
Shows the type of upgrade being run, for example, SIA753. |
