Using Siebel Tools > About the Siebel Tools User Interface >
About the Controls/Columns Window
The Controls/Columns window displays controls and columns available for configuration when editing an applet layout in the Web Applet Editor, as shown in Figure 10. You drag the control or column icon into the placeholder in the Web Applet Editor. When you select a control or a column object in the Controls/Columns window, the Properties window refreshes to show the properties of the selected object. If no object is selected in the Controls/Columns window, the Properties window shows the properties of the applet.
Figure 10. Example of the Controls/Columns Window with the Web Applet Editor
