Using Siebel Tools > About the Siebel Tools User Interface >
About the Web Template Explorer Window
The Web Template Explorer window (shown in Figure 12) is a Windows Explorer-like listing of Web templates. Clicking an item in the Web Template Explorer displays the HTML source code of the Siebel Web Template (.swt) file for review or editing in the HTML code window (shown in the right part of the window in Figure 12). The HTML code window displays both parent and child templates in a split view. The Web Template drop-down list in the Web Template Explorer window lets you filter the templates that are shown in the Web Template Explorer window. You can edit a template file by right-clicking in the HTML code window for that template.
Figure 12. Example of Web Template Explorer Window with HTML Code Window
