Using Siebel Tools > About the Siebel Tools User Interface > About Siebel ToolsSiebel Tools is an integrated environment for configuring Siebel applications. You use Siebel Tools to modify standard Siebel objects and create new objects to meet your organization's business requirements. For example, you use Siebel Tools to extend the data model, modify business logic, and define the user interface. NOTE: Currently, there is no support to customize Siebel Tools. Siebel Tools is a declarative configuration tool, not a programming environment. You use Siebel Tools to create and modify the object definitions (metadata) that define Siebel applications. You do not modify the source code or directly write SQL. NOTE: In the context of Siebel applications, the terms object and object definition are not equivalent to the terms "object," "object class," or "object instance" as they are used in the context of programming languages such as C++. Siebel Tools allows you to develop a single configuration that can be:
You can have installations of Siebel Tools for different product releases on the same local machine. For information about installing Siebel Tools, see the Siebel Installation Guide for the operating system you are using. For system requirements, such as supported versions of Microsoft Windows, see System Requirements and Supported Platforms on Siebel SupportWeb. In this guide, SIEBEL_TOOLS_ROOT represents the directory into which you installed the Siebel Tools client. By default, this directory is C:\Program Files\Siebel\7.8\Tools. |
| Using Siebel Tools |
