Using Siebel Tools > About the Siebel Tools User Interface > About Siebel Tools Application WindowsYou navigate in Siebel Tools primarily using the following two windows:
The Object Explorer uses a hierarchical tree-structure (similar to that of the Microsoft Windows Explorer) that you use to browse the object types that are stored in the Siebel Repository. Other Siebel Tools windows, like the Object List Editor and Properties windows, show you details about individual objects in the Siebel repository. |
| Using Siebel Tools |
