Using Siebel Tools > About the Siebel Tools User Interface >
About Object Explorer
The Object Explorer, shown in Figure 2, appears when you start Siebel Tools. The Object Explorer shows a hierarchical representation of the major object types that you can use to browse the object types in the Siebel repository. By default, the Object Explorer is visible when you start Siebel Tools. The Object Explorer has the following parts: the Project drop-down list, the Types tab, the Detail tab, and the Flat tab.
Figure 2. Example of the Object Explorer Window
Topics in This Section
The Types Tab of the Object Explorer
The Detail Tab of the Object Explorer
The Flat Tab of the Object Explorer
