Using Siebel Tools > About the Siebel Tools User Interface > About Object Explorer >
The Project Drop-Down List of the Object Explorer
Use the Project drop-down list at the top of the Object Explorer to filter objects by project. For example, you can set the Project filter so that only the object types associated with the Account project appear in the Object Explorer. An example of the values in the drop-down list is shown in Figure 3.
Figure 3. The Project Drop-Down List in the Object Explorer Window
