Using Siebel Tools > About the Siebel Tools User Interface > About the Siebel Tools Menu Bar >
Reports Menu
The Reports menu may be empty or may list one or more available reports about objects and properties, depending on which object type is currently active in the Object Explorer. Table 35 in Generating Reports About Object Relationships describes the different reports you can generate using the Reports menu. Two additional reports become available on this menu when the Application Upgrader is active:
- Application Upgrade Object List. Generates a report listing all object differences between repository versions.
- Application Upgrade Attributes List. Generates a report listing all attribute differences between repository versions.
