Using Siebel Tools > About the Siebel Tools User Interface > About the Siebel Tools Menu Bar >
Format Menu
The Format menu options in the Applet Layout Editor allow you to align, resize, and reposition controls; configure the snap grid; and adjust tab or list column order. Options are also provided for performing an Applet Designer Preview. Table 10 describes the Format menu options.
Table 10. Format Menu Options
Align |
Aligns the selected items with the selected model. |
Make Same Size |
Makes all selected items the same size as the selected model. |
Horizontal Spacing |
Adjusts horizontal spacing between items. |
Vertical Spacing |
Adjusts vertical spacing between items. |
Center in Applet |
Centers the selected items horizontally or vertically. |
Set Label Alignment |
Allows you to align labels in applets based on grid layout Web templates. |
Set Tab Order |
Allows you to set the tab order for fields in a form applet. This option is not available for list applets. |
