Using Siebel Tools > About the Siebel Tools User Interface > About the Siebel Tools Menu Bar >
Help Menu
Table 13 describes the Help menu options.
Table 13. Help Menu Options
Option
Description
Contents
Opens the Siebel Tools Online Help.
Using Help
Technical Support
Displays the Technical Support Information dialog box, which includes information that Technical Support may need, such as the version number of your Siebel Tools installation.
About Record
Opens a dialog box that displays information about the current object, including its creator and creation date.
About SRF
Opens a dialog box that displays information about the most recent full incremental compilations.
About View
Opens a dialog box that displays information about the current screen, business object, and view, including applet layout.
About Visible Views
Displays the list of views in the repository and whether or not they are visible.
About Siebel Tools
Opens a dialog box identifying the version of Siebel Tools.
Using Siebel Tools
