Using Siebel Tools > Checking Out and Checking In Projects and Objects >
Checking In Projects to the Server Repository
When you check in projects, the following actions occur:
- Projects and their associated objects are copied from your local repository to the server repository, replacing those on the server.
- Any new objects are added to the server repository.
- Locks on the projects and all associated objects are removed.
To check in projects to the server repository
- Choose Tools > Check In.
- In the Check In dialog box, make sure that the correct repository is selected.
- Click Options.
- In the Development Tools Options dialog box, make sure the server and client Data Sources are are correct and then click OK.
- Do one of the following:
- To check in selected projects, click the Selected Objects option, and then select the projects that you want to check in.
- To check in all locked projects (new and modified), click the Locked/New Objects option.
- Click Check In.
The selected projects and associated objects are copied from your local repository to the server repository and locks are removed.
Related Topics
Guidelines for Check Out and Check In
About the Check In Dialog Box
Setting Options for Check Out and Check In
