Using Siebel Tools > Checking Out and Checking In Projects and Objects > Setting Options for Check Out and Check InYou use the Development Tools Options dialog box to define options related to the check in and check out processes. See the following topics for details about check in and check out options: |
| Using Siebel Tools |
