Using Siebel Tools > Customizing Your Siebel Tools Environment >
Specifying Data Sources
The Check In/Out tab in the Development Tools Options dialog box provides options for setting up server and client data sources. NOTE: For purposes of development, you should maintain only one local database for use with Tools and with your Mobile Web Client, so that changes implemented in Tools can be viewed with the Mobile Web Client. Edit the tools.cfg file and client application cfg files (such as uagent.cfg) to point to the same local database.
To specify data sources
- Choose View > Options.
The Development Tools Options dialog box appears.
- Click the Check In/Out tab.
- Change the ODBC data source of the server repository by doing the following:
- Under Data sources, in the Server field, click the Change button to change the ODBC data source of the server repository.
- Use the information in the following table to define the ODBC data source parameters.
ODBC data source |
Full ODBC data source string that provides communication with the server repository database. |
User name |
User logon ID (in all uppercase) used to access the server database. |
Password |
User password (in all uppercase) used to access the server database. |
Table owner |
Table owner name used to access the repository on the server database. |
- Click OK.
- Change the ODBC data source of the local repository by doing the following:
- Under Data sources, in the Client field, click the Change button to change the ODBC data source of the local repository.
ODBC data source |
Full ODBC data source string that provides communication with the local repository database. |
User name |
User logon ID (in all uppercase) used to access the local database. |
Password |
User password (in all uppercase) used to access the local database. |
Table owner |
Table owner name used to access the repository on the local database. |
- Click OK.
- Click OK.
