Using Siebel Tools > Customizing Your Siebel Tools Environment > Process for Integrating with Third-Party Source Control > Example of Integrating with Microsoft Visual SourceSafeThe following sections provide you with examples for using Microsoft Visual SourceSafe. Check In ExampleYou have two projects checked out that you want to simultaneously check in to the server and to the source control software. The projects selected are "ProjectA" and "ProjectB." The latest version of ProjectA.sif in Visual SourceSafe is 6, and the latest version of ProjectB.sif is 5. When you click the Check In button, the following sequence occurs:
Revert to Previous Version ExampleConsider the situation in which an erroneous definition of ProjectA has been checked in to the server repository. This is stored in Microsoft Visual Source Safe as version 5 of ProjectA.sif. You want to revert to version 4 of ProjectA, because it does not contain the errors:
| Using Siebel Tools |
