Using Siebel Tools > Checking Out and Checking In Projects and Objects >
About Object Check Out and Check In
With object check out and check in, you can check out and check in only the objects that you need; that is, you do not have to check out and check in entire projects. NOTE: If the Allow Object Locking property is set to TRUE, you cannot check out a project from the server. You must set the Allow Object Locking property to FALSE to check out an entire project from the server.
Checking out and checking in selected objects:
- Allows multiple developers to work on objects within a single project
- Improves check-out and check-in times
- Reduces network traffic
