Using Siebel Tools > Checking Out and Checking In Projects and Objects > Enabling Object Check Out and Check InA configuration file parameter controls whether or not object check out and check in is enabled. To enable object check out and check in, add the following parameter to the [Siebel] section of the tools.cfg file, and set it to TRUE: |
| Using Siebel Tools |
