Table 24. Object Check Out Dialog Box User Interface Elements
Repository Text Box |
Displays the name of the current repository the user is working on. |
Object List |
Type |
Displays the type of each new or checked out object in the local repository. Objects obtained by the get process are not listed, because these are not available for check in. (You can check in only projects that you have previously checked out or created locally.) |
Name |
Displays the name of each object being checked out. |
Updated |
A value of Yes appears if the server Locked By and Locked Date are different from the client version, indicating that your version of the object is out of sync with the server's version. |
Object Locking |
A value of Yes appears if this object's parent project allows object check-in/out. |
Server Locked By |
Logon ID of the developer who currently has this object checked out on the server. |
Server Language |
The language on which the object is checked out on the server. Only one language can be checked out at one time. |
Server Locked Date |
Date of check out. |
Client Locked By |
Logon ID of the developer who currently has this object locked locally. |
Client Language |
The language of the object currently locked on the client. Only one language can be locked at one time. |
Project Locked By |
Logon ID of the developer who currently has this object's parent project checked out on the server. |
"Get locale specific data only" checkbox |
Checking this box gets string translations and locale-specific attributes being stored in the locale objects only for the objects selected. It does not get data stored in the locale object's parent object. |
Buttons |
Get |
Selected objects are copied to the local repository, replacing pre-existing versions there, but not locking them on the server. You can get any objects on the server, including those locked by others regardless of whether their parent projects have the Allow Object Locking field checked. |
Check Out |
Copies all selected objects in the selected objects to the local repository and locks them on the server and client. You cannot check out objects that are currently locked on the server by another user, because either their parent projects do not allow object locking or their parent projects are locked on the server. |
Options |
Opens the Development Tools Options dialog box with the Check In/Out tab selected. This is the same dialog box that appears when you choose Tools > Options. |
Cancel |
Cancels the check out, and closes the Object Check Out dialog box. |
