Using Siebel Tools > Compiling and Testing > Testing Changes on Your Local MachineFor testing purposes, you must have an instance of the Siebel Mobile Web Client installed on your machine. After you compile repository changes to an SRF file, local instances of the Mobile Web Client that are open and are reading the SRF file automatically close and then reopen, displaying the updated configuration. For information on installing the Mobile Web Client, see the Siebel Installation Guide for the operating system you are using. When compiling objects and testing the results locally, consider the following:
| Using Siebel Tools |
