Using Siebel Tools > Customizing Your Siebel Tools Environment >
Docking Windows
You can let the Object Explorer or Properties, Applets, Controls, Web Template, or Bookmarks windows float, moving and sizing to fit your needs, or dock the window in a corner of the main window. To dock a window
- Drag the window to the area of the main window where you want to dock.
To undock a window
- Right-click the window, and choose Docked.
To prevent a window from docking when it is being moved
- Hold down the CTRL key during the move.
Related Topics
Showing and Hiding Windows
Showing and Hiding the Object Explorer
