Using Siebel Tools > Customizing Your Siebel Tools Environment >
Showing and Hiding Editors
To show or hide an editor
- Choose View > Editors.
A list of editors appears in a secondary pop-up menu. A visible editor is identified with a check mark. A hidden editor has no marker.
- Select the editor you want to show or hide.
If the editor was hidden, it appears. If the editor was visible, it is hidden.
