Using Siebel Tools > Customizing Your Siebel Tools Environment >
Showing Visualization Views
You can use the Siebel Tools Visualization views to see how objects relate to one another.
To show a visualization view using the View menu
  1. Choose View > Visualize.
    A list of visualization views appears in a secondary pop-up menu. A visible view is identified with a check mark. A hidden view has no marker.
  2. Select the view you want to show or hide.
    If the editor was hidden, it appears. If the editor was visible, it is hidden.
To show a visualization view from the Object List Editor
  1. Display the relevant object type in the Object List Editor.
  2. Right-click an object and choose the Visualization view you want.
    Not all Visualization views are listed for all objects.
Related Topics
Viewing Object Relationships
Using Siebel Tools
