Using Siebel Tools > Working with Objects > About Object Comparison and SynchronizationYou can view a side-by-side comparison of any two objects of the same type. Differences are visually highlighted through color-coded icons. You can select and copy properties and individual child objects from one object to the other. Using this feature, you can propagate a change made to an ancestor object to its descendents or other objects of a similar types. You can assess and adjust differences between objects. You can also compare properties of checked-out objects with their counterparts on the server. For more information about ancestor objects, see Configuring Siebel Business Applications. Topics in This Section |
| Using Siebel Tools |
