Using Siebel Tools > Working with Strings and Other Locale-Specific Data >
Running the String Conversion Utility
The conversion process is implemented as a business service. You run it using the Consoleapp.exe utility, located in the SIEBEL_TOOLS_ROOT\BIN directory of your Siebel Tools installation directory. Prior to running the conversion:
- Make sure you have backed up your database and your repository.
- Make sure all of the projects are unlocked. While conversion and consolidation are running, no other users should be allowed to log on to the development environment.
- Make sure that the DataSource parameter in the [Siebel] section is the desired database. The conversion utility uses this database.
- Make sure that the EnableToolsConstrain parameter in the [Siebel] section is set to FALSE.
- Make sure that the SymStrPrefix parameter in the [Siebel] section of the tools.cfg file is set to the desired prefix. This value is used as the prefix to the name of all newly created symbolic strings. It is set to X_ by default, to indicate that it was created by you and not by Siebel (SBL_).
Topics in This Section
Parameters for Running Consoleapp.exe to Convert Strings
Exporting Candidates for Conversion
Splitting Conversion Export Files into Smaller Files
Importing Converted Symbolic Strings
