Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the String Conversion Utility > Splitting Conversion Export Files into Smaller FilesAfter you generate an export file, you can split the file into smaller, more manageable files. This is beneficial for object types such as Control, because it could have up to 130,000 records. To improve performance, you can import multiple consolidation files, of either the same object type or of differing types, simultaneously. NOTE: An average desktop can typically run about only 10 simultaneous conversion import processes. To split an export file into smaller files
| Using Siebel Tools |
