Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Replacing StringsYou can use the LMU to replace strings in a bulk mode. For example, suppose that you need to change occurrences of Accounts to Companies for the English locale. You can use the LMU to export the strings to a file, manipulate the file so that it contains only Companies instead of Accounts, and then import the strings back into the repository. Using the LMU to replace strings is most useful for strings stored in string-override fields. NOTE: Using the LMU to replace strings is useful when working with string overrides. But when working with the symbolic strings, follow the procedure described in Modifying Symbolic Strings to Globally Update Display Values. To use the LMU to replace strings
| Using Siebel Tools |
