Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the LMU Using the Command-Line InterfaceYou can run the LMU from the command-line interface. Commands, syntax, usage, and examples are provided in the following sections. The syntax for the following commands use these conventions:
NOTE: When specifying file names, the absolute path must be provided. For example, if you specify LMU file as results.txt for export, it is created under the current directory; that is, assuming an installation directory of D:\Program Files\Siebel\7.8\Tools, the file is created under D:\Program Files\Siebel\7.8\Tools\BIN, not under D:\Program Files\Siebel\7.8\Tools\OBJECTS. |
| Using Siebel Tools |
