Using Siebel Tools > Working with Strings and Other Locale-Specific Data > Running the LMU Using the Command-Line Interface > Exporting Strings and Locale-Specific AttributesSyntax/lmu <srclang> <trglang> export <proj|app> <all|string> [<file>] UsageThis command allows you to export localizable attributes for all projects or for all applications. If you specify all, then all attributes (translatable and language override attributes) are exported to a file with the extension of.slf; if you specify string, then string attributes only are exported to a file with the .txt or .xlf extension. If you do not specify a file name, you receive an error. Examplesiebdev /u sadmin /p db2 /d server /lmu ENU FRA export proj all C:\temp\my_proj_results.txt This example instructs LMU to export all attributes (string and language override attributes) for all projects to a LMU file in C:\temp named my_proj_results.txt. The source language is English-American and the target language is French. |
| Using Siebel Tools |
