| Oracle® Retail Integration Bus Cloud Service Installation Guide Release 19.0.000 F25610-01 |
![]() Previous |
![]() Next |
This release contains four PAKs for rib-rwms i.e. rib-rwms, rib-rwms2, rib-rwms3, rib-rwms4. This is to support multiple instances of warehouse. Edit rib-home/deployment-home/conf/rib-deployment-env-info.xml to add instances in scope. Under <app-in-scope-for-integration> add the desired instances in scope.
Example-
<app id="rms" type="plsql-app" />
<!-- The below configuration is for rmws as a master-plsql-app, use this when RIB is on cloud and RWMS is on-prem-->
<app id="rwms" type="master-plsql-app" />
<app id="rwms2" type="master-plsql-app" />
<app id="rwms3" type="master-plsql-app" />
<app id="rwms4" type="master-plsql-app" />
</app-in-scope-for-integration>
Compilation and deployment steps remains same as other application PAKs.
