Siebel Remote and Replication Manager Administration Guide > Reference Materials for Siebel Remote > Server Component Parameters >
Parameters of the Transaction Merger Server Component
Table 51 describes some of the parameters of the Transaction Merger server component.
Table 51. Some of the Parameters of the Transaction Merger Server Component
Error Mode |
ErrorMode |
Optional |
Determines how Siebel Remote handles a database error that occurs during a Transaction Merger process. The default value is STOP. You can use one of the following values:
- STOP. Stops the Transaction Merger server component.
- IGNORE. If all nodes are ignored in an iteration, then the Transaction Merger sleeps.
- DISABLE_NODE. If an error recurs in the same row, then disables all nodes and stops Transaction Merger. If the mode is set to DISABLE_NODE, then the Transaction Merger sets the effective end date to the current time for the remote client that contains the error. You must reextract the remote client to reactivate it.
Sleep Time |
SleepTime |
Optional |
Time to sleep, in seconds, between iterations. The default value is 60. |
