Table 52. Some of the Parameters of the Generate New Database Server Component
Client Db Type |
ClientDbType |
Optional |
Client database engine type. The default value is SQL Anywhere. |
DBA Password |
DbaPwd |
Optional |
Password for the database administrator account. The default value for SQL Anywhere is SQL. You can set the DBA Password parameter to the password of the user ID for the database administrator that exists in the empty database template file. |
Index Space |
ISpace |
Optional |
Space name in the DB template in which to store Siebel indexes. You must not specify the Index Space parameter unless you use the specified index space to build a custom empty database file. |
Interface Tables |
IFaceTbls |
Optional |
Create interface tables and indexes. The default value is FALSE. |
New DBA password |
NewDbaPwd |
Optional |
The password that Siebel Remote assigns to the local database administrator on the remote client. For more information, see Changing the Password of the Local Database Administrator. |
SQL Anywhere Database |
DbfFile |
Required |
Database filename for SQL Anywhere. The default value is sse_utf8.dbf, which is a Unicode file that supports all languages. Alternatively, the sse_encr.dbf file provides standard Sybase encryption of the local database template. |
Table Space |
TSpace |
Optional |
Space name in the DB template in which to store Siebel tables. You must not specify the Table Space parameter unless you intend to use the specified table space to build a custom empty database file. |
Use DDL File |
UseDdlFile |
Optional |
Use when you create a new template file. The default value is FALSE, which instructs Siebel Remote to read the schema directly from the server database. Set the Use DDL File parameter to FALSE only if you run the Generate New Database component after a schema change. Generate New Database then reads the latest schema from the server database instead of from the DDL file. |
Use Transaction Log File |
UseTxnLog |
Optional |
Use when you create a new template file. The default value is TRUE. |
Warehouse Tables |
WarehouseTbls |
Optional |
Use to create Warehouse tables and indexes. The default value is FALSE. |
