Siebel Hospitality Guide > Setting Up Charge Codes, Taxes, and Service Charges > Tax Code Administration >
Creating a Tax Code
Use the following procedure to create tax codes. This task is performed as part of Tax Code Administration, which is a step in Process of Setting Up Charge Codes, Taxes, and Service Charges. To create a tax code
- From the application-level menu, choose View > Site Map > Tax Service Admin > Taxes.
- In the Taxes list, create a record and complete the fields.
- Save the record.
The following table describes some of the fields.
NOTE: You can enter data in either the Amount or Percent field, but not both.
Name |
The name of the tax. |
Currency |
The currency of the tax. Defaults to the default currency of the application. |
Amount |
Tax defined as a flat fee. The flat fee is a preset amount. |
Start Date |
The date the tax becomes active. |
End Date |
The date the tax becomes inactive. |
Percent |
The tax defined as a percentage. The amount of tax charged is the percent value multiplied by the price for the line item. |
