Siebel Hospitality Guide > Setting Up Function Spaces, Sleeping Rooms, and Suites >
Creating Sleeping Rooms
An administrator can define sleeping rooms for the property using the Property Administration screen's Sleeping Rooms view. This task is a step in Process of Setting Up Function Spaces, Sleeping Rooms, and Suites. To create sleeping room records
- From the application-level menu, choose Navigate > Site Map > Property Administration.
- In the Properties list, query for the property, and then click the Sleeping Rooms view tab.
- In the Sleeping Rooms list, create a record and complete the fields.
The following table describes some of the fields.
Name |
A descriptive label for the sleeping room. After the record is saved, click the link in the Name field to navigate to the Product Administration screen > Products view. |
Capacity |
The room capacity. The number of sleeping rooms of that type in the hotel. |
Type |
The sleeping room type. Options are sleeping room and suite. |
Product Line |
If defined, the product line associated with the sleeping room. Click the link in the Product Line field to navigate to the Product Administration screen > Product Lines view. |
Room CRS Code |
The Central Reservation System code for the sleeping room. |
