Siebel Hospitality Guide > Setting Up Function Spaces, Sleeping Rooms, and Suites > Setting Up Suites >
Setting Up Suite Administration
Using the Suite Administration view, an administrator can specify information such as check-in and check-out times. Check-in and check-out information is used when booking suites as sleeping rooms. This task is a step in Process of Setting Up Function Spaces, Sleeping Rooms, and Suites. To set up suite administration
- From the application-level menu, choose Navigate > Site Map > Property Administration.
- In the Properties list, query for the property record, and then click the Suite Administration view tab.
- Complete the fields in the form.
The following table describes some of the fields.
Check in Time |
The time when the guests can usually check in to the hotel when the suite is used as a sleeping room. |
Check out Time |
The time when the guests have to check out of the hotel after sleeping in a suite. |
