Siebel Hospitality Guide > Setting Up Properties >
Defining Airports and Booking Centers
Before a property record is created, an administrator defines airports and booking centers which are referenced in the property record. This task is a step in Process of Setting Up Properties. To define an airport and a booking center
- From the application-level menu, choose Navigate > Site Map > Guest Conveniences Administration Screen.
- In the Guest Conveniences list, create new records and complete the fields for each record.
- For an airport record, set the value in the Type field to Airport.
- For a booking center record, set the value in the Type field to Booking Center.
