| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Product Administration Guide > Mapping eConfigurator 6.x Features
to Release 7.x >Designing Rules and Logical Expressions
The 6.x Basic Rule Designer, Logic Designer, and Advanced Rules Designer have been replaced by the Rule Designer in release 7.x. The Rule Designer provides a series of natural-language rule templates that you can use to create rules of any complexity. You can also create and save your own rule templates.
The logical operators in the 6.x Logic Designer are provided in picklists associated with the rule templates.
A special rule template is provided to enter rules in eConfigurator Rule Language (renamed Rule Assembly Language in release 7.x). The operators and syntax in 6.x eConfigurator Rule Language are supported in release 7.x. Table 4 maps 6.x features to 7.x for designing rules.
Product Administration Guide Published: 23 June 2003 |
