| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Upgrade Guide for UNIX > Postupgrade Tasks > Postupgrade Tasks for All Environments >
Regenerating the Database Template File
CAUTION: This procedure only applies to development environment upgrades. For production environment upgrades, skip this procedure and proceed to Validating Dock Objects and Rule Definitions.
Following the upgrade, you must regenerate the SQL Anywhere template database file used by Siebel Remote. This process updates its schema to the same version as the database server. You use the Generate New Database component from a new Siebel Server to regenerate the SQL Anywhere template database file.
For instructions on regenerating the SQL Anywhere Template file, refer to Siebel Remote and Replication Manager Administration Guide.
Upgrade Guide for UNIX Published: 20 October 2003 |
