| Bookshelf Home | Contents | Index | Search | PDF | ![]() ![]() |
Upgrade Guide for UNIX > Postupgrade Tasks > Postupgrade Tasks for All Environments >
Validating Dock Objects and Rule Definitions
If you deploy Siebel eBusiness Applications to mobile users with local databases, you can run the
DICTUTLutility to verify that all dock objects and rule definitions are correct. Dock objects allow mobile users to synchronize their local databases with the Siebel Server. Rules determine which data users synchronize. For more information about dock objects and rules, see Siebel Tools Online Help and Siebel Remote and Replication Manager Administration Guide.To verify that all dock object and rule definitions are correct
- Type the following command from
$SIEBEL_ROOT/siebsrvr/binusing the parameters specified inTable 24:
dictutl /CODBC_DATASOURCE /U USERNAME /P PASSWORD /D TABLEOWNER /N "REPOSITORY_NAME"/A y 2>logfile.log- Review the
LOGFILE.logfile.
Upgrade Guide for UNIX Published: 20 October 2003 |
